(quoted from post at 13:31:11 10/27/14)
(quoted from post at 12:47:13 10/27/14) Yeah, and after one season of round bales you'll be back to using your small square baler making "idiot cubes."
Why? Because with small squares you make one pass across the field and it is EMPTY. The bales are all nicely stacked on a trailer or wagon where you can move them from place to place just by hitching on. They get handled once or twice more as they're unloaded onto an elevator and stacked in a loft. Inside. Dry. Ready to use. No waste.
Square:
once to stack on wagon
once to put on elevator
once to three times to stack in barn (mow size/elevator)
once to throw down from mow
once to break open to feed
So, you have up to 7 times that one bale is handled by HAND
Round
once picked up in field to put on wagon
once off loaded in yard into barn or stack
once picked from barn/stack and put in feeder
So, you have 3 times that one bale is handled by TRACTOR
Multiply that by how many small squares are in even a 4x4 roll and you will soon find out where the IDIOT in IDIOTCUBE comes from.
Ive seen people store idiot cubes outside with no tarps`, I bet the waste on those is a lot more than a roll. (the rolls I make are covered or inside)
With big rounds, you have to chase all over the field, back and forth, scooping up bales one at a time, and make dozens of trips. Tearing up the equipment and the field. Burning fuel.
That just gets the bales to the edge of the field. Then you have to pick them up, again with a machine, one by one, and load them on to a trailer. Then you either need to drive the loader tractor all the way home to unload them, or have two loader tractors.
Now you get to pick them all up again and stack them somewhere else. You can't get big rounds up in the hay loft, the floor will collapse under the tractor. So you stack them outside where they get rained on for months and months. By the time you use them the hay is half gone and the rest is poor quality.
Why move all the bales to the side of the field when you can load and wagon/trailer direct? Park empty wagon in the middle of a "load" of bales, two bales at a time with loader/3pt spear. If you are tearing up equipment handling rolls of hay than equipment and/or operator is wrong for job.
Tarps were cheap last I checked for outside storage.
Then you have to handle them AGAIN, with a tractor and a loader. Slogging through mud in all sorts of weather to get to them, slogging through more mud to get to the feeder. Want to feed them inside? Oops, the animals are in a traditional old milking barn, back-to-back, with narrow mangers up front. No way a bale is going in there, so now you have to figure out how to slice the bales up and get them into the barn to feed...
I've fed rolls out in a traditional tie stall barn, set them in the barn floor/door (tractor doesn't even need to drive inside) and unroll the bale by hand. It can be done, yes it takes a few minutes, but small price to pay when the entire rest of the process was done by machine.
