Hydraulic oil tank
Anonymous-0
I'm looking for a place that I can a horizontal port. It needs to be so the hose will be parallel with the ground no lower than the bottom of the tank. It wold be something like the bottom ports on fuel tanks where the hose is even with the bottom of the tank. This needs to be 1.5 inch This is for the wetline tank on my Pete. I can get bungs to weld in. Then need to use an elbow or street ell. This makes the line susceptible to everything laying in the road.
I have looked on line to no avail.
What size tank? Check combine salvage yards. Some Gleaner tanks come to mind, if I understand what you want.
Not looking for the tank. I have the tank it is about 50 gal. This is the bung like deal that would weld on the bottom to one end,so you can screw in a hose barb or nipple for a shutoff valve ahead of the hose. They would have welded on when the tank was made.
I looked at my older Pete and the fuel tank is like what I want/need only 1/2 inch. I need 1-1/2 inch.
