Anonymous-0
A MF 699 is discharging the batteries when not in use. As a temporary fix we would like to install disconnect switches, there are two batteries. Is the switch normally installed on the positive terminal or the negative terminal? Seems the negative terminal would have less corrosion.
Also, can someone recommend a switch. I see many types on e-bay. The batteries are very accessible so I would like to put the switch right at the battery. Paul
