Sc CASE....NO Power!
Anonymous-0
Probably should post this on th CASE page, but here goes....Getting my SC running after sitting (inside) for about four years. Cleaned up mag points & contacts & now have spark. It starts good, but is very slow on throttle response & will barely make it up a slight grade in high gear. Just very sluggish. Throttle and governor seem to have proper travel. Also blew out all carburetor passages. Not sure what's wrong.
Glenn F.
I sure appreciate your horse sense Old. I suppose it could be rings, but seems unlikely to me.
Wish you were 1000 miles closer.
Glenn F.
Any time an engine sat for over a year the ring tend to stick and since that happen I bet if you checked compression you would find it to be low
