Pulled the 656 out of the shed or was going to the clutch worked fine when it was put away last fall now the thing will not release?
Tried low gear with clutch in and brakes on just killed the motor.
Any ideas short of splitting it again clutch has about 150 hrs on it. ?
Tie the clutch pedal down, then take off the starter. You can work through the hole with a blade to unstick the clutch disc from the flywheel, through the gaps in the pressure plate. Or if the pressure plate doesnt have gaps, loosen the bolts to create a gap.
(quoted from post at 10:45:18 05/04/14) Pulled the 656 out of the shed or was going to the clutch worked fine when it was put away last fall now the thing will not release?
Try it again, but use a higher gear.
