I have a splined shaft that has a hub that is held on with a nut. It does not run very fast. The nut came lose and it wore the splines some. The whole machine is not worth the cost of a new shaft and hub (over $1000).
I remember using a loc tight product on truck differential yokes. You cleaned both the shaft and yoke. Then you sprayed a primer on both. Then applied the Loc tight. This really worked well.
I can't remember the number or the exact name of the products. I would need the primer and Loc tight both.
