glennster
ok here is the latest on the 2001 powerstroke in our 450 s/d wrecker (5spd 140k miles) it has been having intermittent power losses. truck will run fine and then just loose power. will barely run 40 mph. has already been to 2 different diesel shops. many thousands of dollars have been spent to correct this problem. sensors, fuel filters, oil changes, air filters ect. never threw a code. so out of desperation, dropped the fuel tank and found a little goo in the filters in the pickup. and the pickup was sucking air. replaced that and also changed the cam sensor with a napa one. didnt help. had another diesel mechanic work on the truck over the weekend. check all the wiring harnesses, all good. so he decided that the napa cam sensor was at fault. new ford sensor. the he changed the oil pressure/fuel sensor (above left valve cover. nope. then he changed the temp sensor. nope, then the temp sender. nope. then he changed the pcm. nope. now it misses bad and backfires. finally threw a code, he said injector synchronization. but he is at a loss. now we are in worse shape than before. arrrhhhhhh....another couple grand down the toilet. i wonder if i can put an old 1150 cat in this truck......or an old detroit.....i plan on re-scanning thetruck tomoorow and see if i can pull any new codes with our modis scanner. he was using an otc.
