JD 60 with 12v neg ground system and delco 10si
hooked up for the first time today. Jumper from
Batt to #2 terminal on alternator. Indicator
light in wire from IGN to #1 terminal on
alternator. Light illuminated even with IGN off,
must be backfeeding through #2 terminal jumper?
Alternator was a new reman from NAPA. Charges
15amps and tractor runs and shuts off fine.
Alternator seemed warm after several minutes
hooked to battery. Continuity noted across
terminals #1 and #2. Did I get a bad alternator?
And what else have I potentially fried? If it is a
bad alternator and NAPA won"t replace should I
take it apart and just put in a new $10 regulator?
What about not hooking #2 to batt terminal?
Thanks for input.
Thanks for input.
