Anonymous-0
Dad has an older Gehl skid loader with a Ford gas liquid cooled engine. It has always been very cold blooded. It is hard to get started when it's cold. I figured it needed the choke adjusted so I pulled the air intake hose off the carb and looked in and it is closing all the way when you pull the choke and opens all the way when you push it in. When you pull the choke with it running it makes some difference but not a lot. Most gas engines I have been around will die or nearly die when you choke them. Any ideas what might be going on here? Or what else to look for?
