I have a ring roller that I"m trying to ID who made it. It is quite old. The hangers on both sides for the axle are castings with A21 in the casting on the inside. The end caps for the axle are stamped S14 on the outside. The toothed rings are cast also and PATD 2 15 27 is cast into them. The end caps have zert fittings and they appear to have had wooden inserts between the caps and the axle.
This ring roller also has two smaller rollers (pups?) that attach to the angle iron frame with their own draw bars to work a wider path.
Any help would be appreciated.
I will try to add some pictures later.
