Heat Pumps---Another Question
Pappy
At the farm, heat pump works fine. My question is how can a heat pump, using the compressor, be more efficient than the heat strips included in the system. The heat pump compressor runs for a long time, but the heat strips will warm it up in a few minutes. I know a little about electricity, but very little about heat/refrigeration. Can you explain this so I might not be so ignorant??
Your heat pump might use 3000 watts to run where the heat strips are probably 10,000.
So the compressor can run 3 times as long on the same energy used.
Gary
A heat pump moves heat from one location to another. Even if the original location is colder, the pump can still get heat out of it and move that heat to someplace else.
Like your refrigerator, it is not really making cold inside of it. It is taking the heat inside the refrigerator and moving it out to your room.
And the air conditioner is adding heat to the outside world, making your house colder.
A heat pump takes heat out of the air outside, or the ground in a colder climate, and moves the heat into your house.
It does not take much electricity to do that.
paul
the coefficient of performance is a measure of how much the unit moves vs. the power it takes to move it. many of the heat pumps units are a COP of 3, meaning they move 3 times the "heat" they use to make it move. that's where the advantage is.
the coefficient of performance of a heat pump is about 3.5 to 1 at 47 degrees outside , 1.9 to 1 at 17 degrees outside and 1 to 1 at 0 degrees outside . you can see where you use ground water at 47 degrees how efficient a unit could be .
The thing to understand is that whatever energy you put into the heat pump comes out the hot side, PLUS whatever heat it's able to pump out of the air on the cold side. So it will NEVER be less efficient than resistance heat, and will normally be significantly better.
For example, let's say you run your 1500 watt resistance heater for one hour. That's 1.5 kilowatt-hours x 3413 Btu/kw-hr = 5120 Btu.
Now let's say you ran your heat pump long enough to use that same 1.5 kw-hr, and at the particular inside and outside temperature the heat pump has a Coefficient of Performance of 3. You'll get three times as much energy out as energy in. So that 1.5 kw-hr gained you 3 x 5120 = 15,360 Btu.
"So it will NEVER be less efficient than resistance heat, and will normally be significantly better."
With moving parts you will always have wear. With fossil fuel or electricity there are no moving parts. You can talk efficiency all day long, but in the end the repairs will be the true measure.
I did not say the total cost of ownership is cheaper for a heat pump than for resistance heat. Obviously that depends entirely on the application. Let's say you live in southern California and you rarely need either heat or air conditioning; resistance heat will do fine and if you can live without air conditioning it's probably cheaper to go with resistance heat versus a heat pump. But let's move to the east coast, say North Carolina: Air conditioning is pretty much mandatory, and the incremental cost of a heat pump over an air conditioner is negligible. You'll save a ton of money heating with a heat pump over resistance heat, yet the cost of depreciation and repairs is about the same as if you'd installed only air conditioning.
I don't know why you bring up fossil fuels. The question was the relative efficiency of heat pumps versus resistance heat.
Do you have central air? If you do you already have a heat pump. A air to air heat pump is just a air conditioner that will reverse in winter. I have a heat pump water heater also. Runs for 1/3 of a electric resistance one.
"the coefficient of performance of a heat pump---" Good information. I had not seen those ratios posted anywhere before now. Last night at 17 deg, my heat pump was doing most of the heating with the auxiliary light coming on occasionally. That might have been for the defrost cycle.
No central AC. A high efficency window unit in both ends of the house. My utility bill (including $30 for water and sewer) ran $150 for a 1,800 sq. ft. house, single level in the coldest month last year which was January. This is with baseboard electric heat in every room. I only went over $100 twice in twelve months. My house is well insulated with good windows.
1/13 $120
2/13 $100
3/13 $90
4/13 $75
5/15 $60
6/13 $59
7/13 $65
8/13 $70
9/13 $55
10/13 $60
11/13 $75
12/13 $90
I'm on a low rate because my house in all electric.
Two things can be extrapolated from your data:
1. You don't live in Florida.
2. You don't live in Minnesota.
As far as providing any insight into the relative cost of heat pumps versus resistance heat, you've added nothing to the discussion.
I live in Central Illinois as I have previously stated. The owner of a HVAC business that is in the third generation of ownership told me personally that he would never have a heat pump and prefers natural gas but he installs them (no bottom dollar units)because the utility recommends them and gives a rebate.
What your numbers and location really show is you have no way of telling how good a heat pump is.
It is simply not made to work in your area.
A heat pump is made for the south where there are days in December when we run the A/C and we rarely get more than a few hour snap where it is below 32F.
Yes if you live in the fidget north (above I 20) a heat pump may not be your best choice. This is because the backup heating coils are constantly working to compensate for your poor choice of installing a heat pump. But if you lived in the deep south where central A/C is a MUST have and heating is just a small comfort feature you might then realize heat pumps are a choice you may want to consider.
How many kilowatts of electricity are you using? That will level the comparisons with respect to rebates/discounts you are getting being all electric.
So with propane here in a rv park costing $4.50 gal an elect @.15cents it is far better to heat a rv with the heatpump on our rv?
Coefficient of performance at 3 is under ideal conditions so don't expect to actually see it. One other thing people don't realize is when it gets frigid like it has this week a heat pump is less efficient than the resistance heat strips the emergency heat uses. Any heat pump will check the coil temp every thirty minutes, hour, or hour and a half to see if it needs defrosting. With the frigid temps we've seen this week it will go into defrost and switch to ac every time it checks. The heat pump uses the same amount of power whether it's running in heat mode or ac mode BUT every time it goes into defrost you are also using the heat strips to counter the ac. That's when it's using more power than plain old resistance heat.
What did I say that was BS? I said you don't live in either Florida or Minnesota; correct on both points. And just because you get your electricity essentially for free doesn't mean resistance heat is cost effective for most folks.
Excluding any residual electricity to run supplemental heating elements that a specific unit may contain, the heat pump acts in reverse to an air conditioner. It relies on absorbing the heat in ambient air to generate it's output. The less of the above, the less the performance, without considering efficiency. So the colder the weather the worse the conversion when you need the best of conversion.
Other thing is that if you have a dual use window AC you are at the mercy of the cooling/heating fins which are the limiting factor in the system due to corrosion and congestion from external debris.
No way would I waste my money on such a contraption.
Mark
I work on straight cool and heat pumps and I prefer the straight cool over heat pumps any day. the cost of repair and the ease of diagnosing a straight cool is way better. Plus, when you use straight cool the compressor is not running every day out of the year to wear out the compressor. Straight cool does not have defrost boards to diagnose, no reversing valve or reversing valve coils. Too me a heat pump is a waste of money. Now let me also add that a straight cool thermostat has only 4 wires, the ones I work on have 8 wires.
