Fujitsu Mini Split heating/cooling systems
Doversix
Just curious is anyone using these systems as their main heat source in the Midwest, Iowa or Minnesota? How is it working for you?
My Mitsubishi ductless unit doesn't have auxiliary heat, and I doubt that any of them do. I seriously doubt you can heat adequately in the midwest on heat pump alone. If you have one room in the house that currently has neither heat nor A/C it would be worth a try; otherwise I would forget that idea.
