MH44 EFI coil pack plate
David G
I got the coil pack plate painted and installed today. It has coil pack on left, place to mount the 2 coil driver transistors in middle and oil filter on right.
I must be getting better at fabricating, did not have to oversize any holes this time.
I do not know, it would get a turbo if the engine had more than 3 main bearings.
The good news is that things are getting simpler 2nd or 3rd time of trying them. My first attempt was usually the most complicated.
It is a microsquirt controller.
I was reading on Keystone Turbos site that a turbo will put less stress on the engine than adding rpms! I am not sure. Thanks for the pics and info, I am looking into running an Oliver on ethanol, well at least e85. The plan would be to take a gas engine and up the compression to around 16.1. Would you have any ideas behind this? The idea comes from wanting to make my own fuel and from the Oliver xo-121 experimental tractor. Thanks again. Tom
