pto shaft 2000ford tractor 2stage clutch is it simply 4bolts slide out slide in ? no dropped washers like ind pto4000
pto brake band 6610cab can it be installed from side plate; minimally invasive???
thanks campbell
Campbell you might get a response on the Ford spot below, not sure about the PTO on the 4000 but pretty sure the brake on the 6610 requires a trans split.
