Dennis2266
New User
I have a IH 3514. The pto just quit working. I don"t kow if th pto is hydrostat or mechencial. Looking under the tractor it apperas to be mechencial. Anyone had an issue similar. Can I get to the root of the problem by pulling the shaft plate or do I have to split the tractor. It has the 239 diesel engine.
Hi Dennis, the 3514 is based on the ag 504, 544 tractors and if it has a German D-239 Diesel engine then it is based on 544.
Some of those tractors had a PTO disconnect lever under the torque tube. It was a small lever with a bolt thru it. Bolted in one position enabled the PTO and the other position disabled the PTO.
I am not sure the 3514 has this lever or not.
JimB
