Needing to install a speedi sleeve into a close clearance area. Not much room between the bearing and the oil seal. What is your guys best technique for removing the flange without distorting the sleeve? There is a weep hole for lubing some internal needle bearings that would be covered by the flange. Also, has anyone installed a speedi sleeve backwards? Thinking if there is too close of clearance that removal of the flange would cause the edge of the sleeve to be on the seal, would I be able to install it backwards, flange on last? I would think this would be a big No-No but asking never hurt. Thanks a bunch!
