old
- Location
- Camdenton Missouri
Well not sure if the guy has the correct parts or what but, I got the old one out on the drivers side. Tried to install the new one and first off the brass bushing as I hammered the pin in peeled a lot of brass off of it. Next got to the point that the pin is in about 1/3 of the way and will not go in more and that is with an 8lbs hammer. The part and company is this Thrayer or Trayer #TPTK411 30354-2834 so if any body know is this the correct pins?? Have a set on order and will be in on Tuesday so I can compare to see if theses are right or wrong or what. Yes I reamed things out as was told to do with a brake hone etc and no go. Stopped this after noon due to rain and could not post this earlier due to lighting
