(quoted from post at 05:28:52 08/27/12) So there is no need to be careful or use safety
equipment because then your number is up, it"s up?
(quoted from post at 07:20:14 08/27/12) It's a number game.... That guy just happened to be loading his tractor when the big guy pulled his ticket..... We've all done stupid things that shoulda killed us and are still here namecalling. I'm a walkin miracle as far as that goes :roll:
(quoted from post at 05:43:43 08/27/12)(quoted from post at 07:20:14 08/27/12) It's a number game.... That guy just happened to be loading his tractor when the big guy pulled his ticket..... We've all done stupid things that shoulda killed us and are still here namecalling. I'm a walkin miracle as far as that goes :roll:
So Dave if utilizing your NUMBERS theory if you stand between the 2 tracks of a railroad and the train is coming if if it stops before it gets to you your number wasn't up?? :lol:
(quoted from post at 08:50:39 08/27/12)
The likelihood of your number being pulled is closely related to the amount of common sense you use.... sometimes a species has to be culled a little....
(quoted from post at 06:02:51 08/27/12)(quoted from post at 08:50:39 08/27/12)
You're one to chastise me about common sense!!!!!!!!!!!! :wink:
(quoted from post at 06:06:59 08/27/12) The "your number is called" and all of the other myths worked pretty well until mass transit and instant news became available.
If the "your number is called" is true, then next time you are on an airplane, better hope NO ONE on that flight has their number come up.
(quoted from post at 06:14:56 08/27/12) "When your number is up, it"s up" maybe even
valid on the battle field given the conditions.
A non combat loading of a tractor at a show
should be safer than dodging 7.62x39 slugs, IUD"s,
RPG"s, mortar/artillery fire, mines, friendly fire.
Or having somebody driving combat equipment take
evasive maneuvers and run over some of his own
troops.
(quoted from post at 09:12:26 08/27/12)
don't take everything personal.you'll get yourself all worked up and cause your ankles to swell or sumpin..........
(quoted from post at 10:12:55 08/27/12) That auto spell checker can be embarrassing.
(quoted from post at 13:02:19 08/27/12) Probably, thru, through,threw, plow, plough,
tire,tyre,
(quoted from post at 10:18:46 08/27/12)(quoted from post at 13:02:19 08/27/12) Probably, thru, through,threw, plow, plough,
tire,tyre,
But davey's states he's a USA citizen and that narrows down correct spelling some that is if he went to school in USA.
(quoted from post at 13:27:39 08/27/12)
Now go find a busy intersection and play with your tonka trucks in the middle of it....
