MH 44 Zenith Carb
David G
I took the carb apart on the 44 today to start through it. There is a brass bushing on the throttle shaft that is shot.
Where can I get a replacement shaft and bushing?
Is there a round brass button on the top of the carb with some numbers stamped on it? If so, the model and serial numbers will be there.
That carb should be one of 2 that they had. One is the 10444 and the other is the 10279A if it is the 4 cylinder model as per the nnalert catalog. I could also check the carb on the 44 I have tomorrow
