flush hydraulic system
Anonymous-0
I bought a flail mower with a fence line mower attachment. It is a little flail mower on a swing arm on one side. I found out that it was under water for about a month. The self-contained hydraulic system is full of oil-water mix with no drain plug on tank. I was going to take off the return line and run it slowly until it sucks air and add new oil untill I get clean oil coming out. Will this work? Thanks, Sam.
why not try hooking it to alr and gently blow it out then pour some cheap oil in the inlet line and blow with air
