wilson ind
SUper M TA recently bought from old gentelman . Battery is hooked positivr gtound as per manuel. Add on lights were not hooked through amp guage. Generator would not charge. Unless ground cable (positive ) was unhooked would sometimes discharge battery. After getting light wire through amp guage lights shoe discharge as they should with engine shut off. Problen is when engine is running generator shows about 7 to 10 amps discharge. When jumped bat to field while running discharge rate went to 20. The generator is working i guess just in wrong direction Regulator looks rather new. If regulator is neg ground only would this cause the problem?? Was it polarized wrong when I bought the tractor?? How can I fix it?? GLEN I do have I&T Manuel!! just does not help or I am to dumb to understand it!!
