I'll try to keep this as short as possible. I blew the front mounted hyd. pump on my 202 MF. It is a Cessna K 20644 ICEH and from what I understand you can not rebuild them once they are worn out....and this one is worn out! Has anyone had any luck finding a suitable replacement? I can find pumps that have the same or close enough specs to work but the shafts are always different. Mine has a 3/4" keyed shaft which is 1 1/4" long. Are there adaptors available. One thought I had was to get one with a 5/8" keyed shaft (I've seen a few that would work) and shim it with some 1/16" shim stock. Or would I be better off trying to find/make an adaptor or trying to find/make a new drive shaft for it?
Any thoughts appreciated. I've spent too much on this old tractor to stop now!! :?
