super M pump
ohiojim
i have a farmall 1952 super M, it has the belly pump hydraulics,..would like to put the live hydraulics like the 53 has,...will the pump off a 53 fit the 52 and if so is there anything else i have to change...
(quoted from post at 05:09:48 10/25/11) i have a farmall 1952 super M, it has the belly pump hydraulics,..would like to put the live hydraulics like the 53 has,...will the pump off a 53 fit the 52 and if so is there anything else i have to change...
As memory serves me, there is a slight difference in the pump mounting bolt patterns.
the 52 has the later style timing cover that will accept the live pump. the very late m's and the stage 1 supers were set up with the heavier camshaft gear and the newer style covers , so it will be a direct bolt in.
yes it will work fine with no modifications.
BTW, there's a forum on this site dedicated to IH stuff if you'd care to check it out. "Tractor Talk" is mostly a politics forum.
I agree, you won't need any modifications here.
(quoted from post at 06:30:08 10/25/11) yes it will work fine with no modifications.
BTW, there's a forum on this site dedicated to IH stuff if you'd care to check it out. "Tractor Paint Talk" is mostly a politics forum.
