Anoither tranny question
Kid just bought a 93 half ton chev 4x4 from a neighbor farmer, high miles, was his Sunday go to church truck and his wife drove it to work, not a scratch on it!! But 228000 miles. It has no high gear, fluid looks and smells good, ist, 2nd, and reverse work great, when it hits 3rd motor just winds up, nothing at all. I think the kid said it's a 4L60E auto. I never got into anything newer than a 7004R, any ideas?? Thanks for your help.
If it disconnects when it shifts to 3rd, then you've got something broken in there. You will probably be money ahead to swap out a fully remanufactured unit instead of trying to repair yours. If you can do the work yourself, do a Google search on the 4L60E and you'll find lots of options. In any case, it sounds like the truck is worth fixing.
Good Luck and God Bless
The 3-4 Clutch Pack is burnt (failed). Most common failure. 3rd and 4th share the same clutch pack, the 2-4 band comes on in 4th to hold the reverse input drum to hold the sun gear to get overdrive. The 4L60E is the same basicly as the 700 but just electronic with pressure control solenoid controlling the line pressure and not a cable and throttle valve. Pull trans and over haul. Set clutch pack clearence to .030 to .040 for 3-4 clutch pack. I build these everday in a GM shop. replace the coverter and the pressure control solenoid. any other questions just ask.
best bet is a reman. Thats what i recommend to the do it yourselfer that can atleast pull it and replace it. trust me. Lotta special tools for seal sizers and such. reman has a better warranty than you doing it yourself.
My guess is burnt out 3/4 clutches. When the 3/4"s give up, thats what you get, neutraling out on the 2-3 shift.
If you were missing first and fourth then you could be electrical(bad shift solenoid).
Like Brian said also, could be a blown sprag if you have to manually pull it into 1st or 2nd to initially take off. Either way, it sounds internal to me..
Why in the world would ya replace the converter and the step motor?
Yeah, I spent a couple of lifetimes under those rascals too.
Allan
With 228,000 miles, changes are that's not the original transmission, but I guess stranger things have happened. :>)
Does it actually try to shift? As in second just drops out and you have nothing but neutral? If so, these other fellas are right; 3/4 clutch.
BUT, if it doesn't even TRY to shift and just stays in 2nd, check that fuel filter. Could be that's all that is wrong with it.
Allan
Why wouldn't you? I pull i build these in 7 hours flat. This guy gunna have alot more time in it then that. MTS in Omaha sells these converters for 120.00 bucks. cheap insurance for him. At the shop here (GM Dealer) i RARELY replace converters cuz i m overhaulin units with less then 100k on them. some only have 10k on them. And GM doesnt want 600.00 converters throw at every overhaul. At 228000, its time.
As far as the Pressure control solenoid goes, when you have a clutch failure that solenoid acts like a magnet and collects all the faris meterial and can affect line pressure. Again, just CYA for him. His best bet is to buy a Cerified Transmission replacment.
Thanks everyone for your input, looks like it will have to come apart, I was thinking maybe a solenoid or something easy. Neighbor bought it new and it's the original trans. In drive it shifts 1-2 real nice and 2-3 just like you bumped it to neutral, reverse is also right there. It's a nice truck and he only paid $350 for it. I have a wholesale place in the Twin Cities to get parts, so another project for this winter, thanks again!!
Okay,
It's "soot" time, looks like. What's nice about those old sisters is that ya can "repair" 'em in one heck of a hurry if you know the fault.
I don't even take the valve body off; just yank the guts right out the top, throw in the seals and plates and back into the rig again she goes. :>)
Hardest part is "bending" that silly transfer case down outta there. :>(
Allan
Well yeah,
If ya don't know the history on the outfit.
But ya gotta admit, 18 years on a set of GM seals is really pushin' it to the limit. Especially up there in his country.
Ya just KNOW it's been rebuilt at least once. :>)
Allan
(quoted from post at 12:32:48 10/25/11) Okay,
Allan
I Take it all out as one unit.. I have worn out several homemade tools removing the torsion bars,, about a year ago I brought the OTC special tool to remove the torsion bars,,, since then I have not had to do one,,, that's how it goes you tool up and never see one again...
(quoted from post at 12:39:57 10/24/11) The 3-4 Clutch Pack is burnt (failed). Most common failure. 3rd and 4th share the same clutch pack, the 2-4 band comes on in 4th to hold the reverse input drum to hold the sun gear to get overdrive. The 4L60E is the same basicly as the 700 but just electronic with pressure control solenoid controlling the line pressure and not a cable and throttle valve. Pull trans and over haul. Set clutch pack clearence to .030 to .040 for 3-4 clutch pack. I build these everday in a GM shop. replace the coverter and the pressure control solenoid. any other questions just ask.
What he said, and just to add... You might want to pull the pan and check the magnet. if it does come out clean, and fluid is clean... disconnect the battery. wait 15 minutes, reconnect, then try again. chances are it won't work, but worth a try. I have had a dirty electrical connection after a complete rebuild on one of those. I am a ford guy, so I don't know much about them, except for 3 700r4 rebuilds I did. The last 4L60E I played with just had a dirty plug. someone replaced the transfer case, disconnected all the plugs, and got dirt in them putting back together. It was rare, but, it happened.
Hey Pard,
Ya really don't have to go thru all that.
6 bolts holding the transfer case to the transmission adaptor and that case will tip right down out of there nose first.
Allan
