WHAT’S UP GUYS:
I have been asked to fix this, All he wants it to wield the top like it was done before; I have told the owner that the reason it did not work the first time is because there is way to much stress in that one area, and it will never hold.
I told him he would be better off to replace the spindle and the steering arm and do it right. His answer was how much I replied depending where you get your parts
Will depend on how much it will cost: I told him if you buy new parts, the will cost about
$450.00 to $600.00. He just about sh-t a new tractor then I told him that was for parts ONLY now the labor Thin I told him the lab, would be about $100.00.
Then he said: NO NEW PARTS: JUST FIX IT ,So I ok:
This is my plan tell me if it will work:
I will take off the steering arm, Square the wheel up , Drill a hole in the side of the steering arm ½ or 3/8th put the arm back on mark the spindle shaft drill a ½ or 3/8th hole about ¼ ‘’ deep in the steering arm and then tap out the hole in the steering arm for that
Bolt size that I use and make a set screw for it: Will this work, If not what will:
MANY THANKS GUYS
JR FRYE
![a50749.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a50749.jpg)
