old
- Location
- Camdenton Missouri
Ok so I have 2 hyd cylinders that I want to remove from the part they are in. So far I have not been able to get either pin so so much as move a 1/16 of an inch. One the one I can get my port-ta-power but it is only a 4 ton unit and it does not move the pin. So any ideas of how to get the pins out???
Thanks. Oh by the way these are single acting cylinders if that says any thing and are the cylinders off a Sherman back hoe the part you have on the ground to hold the unit from moving
