When I first got goats, I was hauling water out to the pens to fill the tanks. Then I wised up and installed an outside hydrant on the back of the well house (closest place to the goats I had water) so I could just drag a hose out there. Well that's 150 feet and honestly I was getting darn tired of dragging that much hose once a week. So I decided it was time to dig a ditch and run a water line a bit closer.
Not having a trencher, nor the money to rent one I decided to utilize what I have. I have a root cutter and a middle buster for my Ford, so I had at it. As you know, when trying to dig a ditch in this manner, the dirt tends to fall back in the ditch. At least I do own a drain spade (bill dookie) so I was able to clean the ditch out, but dang with this heat index of 107 it makes it some mighty tough work for an old guy.
As you can see I borrowed the wifes pop up canopy to make myself some shade of the area of the ditch I was having the clean out. You have to appreciate any shade you can get when it get's this darn hot
I also had to set a post to mount the water hydrant to, so out came the post hole digger.
There we go, 3 feet deep. That should do it. BTW, our frost line might be 2 inches during a bad winter, so not much to worry with. The ditch is 18 inches deep which will keep the water line from breaking under the worst of circumstances here.
And I got the post set and braced and began running the PVC. Didn't finish up until after dark so I never got any more pics but once completed I turned the water on and no leaks. Makes for a good end to the weekend. Of course, now I still have to cover the ditch, UHG!
![a45048.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a45048.jpg)
![a45049.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a45049.jpg)
![a45050.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a45050.jpg)
![a45052.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a45052.jpg)
![a45057.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a45057.jpg)
![a45054.jpg](https://photos.yesterdaystractors.com/gallery/uptest/a45054.jpg)
