Ken Macfarlane
The double ended ram on my MF's steering is internally threaded, I'm trying to remove a tie rod end from it while on the tractor.
I've used lead sheet with pipe wrench, vice grips, chain wrench etc but the lead slips. There are a tiny set of 1" flats but the only wrench I have slim enough to go on it just spreads the jaws when you try to turn the tre.
I've never heated anything chromed before that I cared about, hot hot can I get the steering cyl? Its out all the way on the side I'm working so I can cool the seals.
