farmall fornt wheel
i nned some help here guys/girls,i have a farmall h i want to put a single front wheel on i found a auction they have 2 they do not know if they are for.so if you could help me out and if they take a regular 6 bolt implemnt wheel? thanks heres the link http://smithsales.auctionflex.com/showlot.ap?co=11217&weid=17853&weiid=6507086&archive=n&lso=lotnumasc&pagenum=9&lang=En
It appears in the pictures that the one with the rim is a 5 bolt, and the one with just a hub appears to be a 6 bolt. I am guessing the one with just the hub would come the closest to fitting your H, but no guarantee because it might have previously been on an M, and the two will not interchange. You will want to measure the bolt spacing on your H before you start bidding.
A regular implement wheel most likely will NOT have the correct offset, but if you can find one with NO offset it would probably work.
(quoted from post at 10:54:31 06/16/11)
so do you think it would be easy to find a narrow rim that would fit the one with just the hub? thanks aaron
I'm sure a new rim with the correct dimensions can be bought. Might even be a used one or two out there somewhere, but it would be tough to find a GOOD used rim. I may be able to help get a new one.
(quoted from post at 06:06:04 06/17/11)
how much do you think a new rim would be? so you could get one for me? just trying to make sure i could get one before i buy it thanks aaron
