Massey 35 Steering column issue
I have a Massey Ferguson 35 .The steering wheel turns freely 360 degrees.This was repaired a number of years ago,and I believe there are some large roller bearings in there some where.
Can anyone help me with this problem ,what to look for and what I need to do to get to the problem and repair it.
Let me guess, you have a front end loader and no power steering?
I had the same thing happen to my 202 (pretty much the same as your 35) twice. The second time I got smart and designed a hydrostatic power steering system for it.
There are recirculating balls and a worm screw assembly. What happens is from the torque you are placing on the steering shaft, the ball bearings either get worn down or crushed and start popping out the sides of the "block" that houses them. The unit is probably beyond repair by now and will have to be replaced.
http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=MF&&md=35&cat=Steering&r=mcats
Scroll down the page and you will find a replacement steering shaft which includes the ball screw assembly. Problem is if you have a lot of weight on the front end (loader especially) you will eventually break it again. You need power steering if you have a front end loader.
I was able to achieve a very good power steering system, much better than original for around $700 or so with some used parts.
