F250 questions
Howard H.
I've got a 2000 F250 with the 5.4l V8 gas engine.
It was cutting out going up a hill with a small load on my trailer this afternoon... Does anyone know what the proper pressure should be at the rail on engine?? A gauge showed 22-24 with it hot idling... I replaced the fuel filter shortly after I bought it last fall.
As many fuel pumps as I replaced on my old '94 & '92 F250s with 351s, I'd have thought Ford would have improved the fuel pumps by the year 2000!
Thanks a lot,
Howard
I sort of wondered that - but it doesn't act quite like it did when I DID have a coil go bad. Besides, Autozone was able to put a code checker on before and see which cylinder was misfiring - this time it didn't show any codes related to the coil-over-plugs.
It just showed a set of "lean bank 1", and "transition" type errors.
But overall - it just seemed like it was starving for gas...
Howard
Coil related problems on 5.4 Triton engines are very common. Lots of times a bad coil will not set a code. You need someone who has a good scan tool to access the engine control module under generic mode and go to non continuous monitors. At non continuous monitors, to to $53 and look at the counters for actual miss fires to know which cylinder is miss firing.
Hope this helps,
How many miles on the spark plugs.We bought an 89 Mercury.The lady that we got it from said,If it starts to stumble ,it needs new plugs.
