Hendrik
My Holder two stroke diesel tractor blows partially burnt engine oil from the engine exhaust. (This is the nature of the beast since it has an oil injection system versus a circulation pressure system as found on most four stroke engines.)
The fan pulls some droplets into the radiator. Over the years, a greasy crud has built up on the radiator fins to the extent that you cannot see through the radiator while in a clean(er) area you easily can. The crud causes the engine to overheat. It is a thermo syphon system.
Hoe can I remove this crud? I applied industrial grade degreaser followed by rinsing with hot tap water but that doesn't seem to help much.
Any and all advise appreciated! Hendrik
