Company Logo (800) 853-2651 Shop Now
john deere cam grind advice
ricflair
01-22-2023 07:22:48
I am restoring a B, exhaust cam lobes are worn, would like to get it ground with a more effient profile.
Who should I have grind it? I hear good things about Bullet. Has anyone used extreme pulling parts? I think Denglers is out of business?
Thanks
6cylpower
01-27-2023 07:26:32
 Re: john deere cam grind advice in reply to ricflair, 01-22-2023 07:22:48
No keys on a B cam, it bolts to the gear. Slot the holes if you want some advance.
ricflair
01-22-2023 16:48:47
Ok, sounds the same as auto. Thanks
ricflair
01-22-2023 11:58:32
How do you degree? Do you have to have the gear holes slotted?
Thanks
VicS
01-22-2023 15:08:15
 Re: john deere cam grind advice in reply to ricflair, 01-22-2023 11:58:32
It's to complicated to explain here. But just ask Google. I have just done it 2 times, both times the cam grinder had it dead on. You will get a spec sheet with your reground cam. Might have to make a offset key for your crank gear or get another key way made in it. Or maybe change the cam gear key, to a of set one. Of course you need a.dial.indicator. They really run good when everything is right. Also I would find a good speed shop and get everything balanced. Your flywheel is probably off the most.
504
01-26-2023 17:21:15
 Re: john deere cam grind advice in reply to VicS, 01-22-2023 15:08:15
Off set keys have been around for years.Iskenderian(Isky Cams) is one manufacturer.
TVMAN
01-22-2023 08:14:54
I have had 2 ground by josh Blackburn in Michigan done good job also It will have be degreed in when installed thanks TVMAN
Today's Featured Article - A 1937 John Deere Unstuck - by Gary Hickman. Here is my story of how I got the pistons out of a 1937 JD B that the engine had been stuck for about 14 years: About 12 years ago my Dad gave me one of the tractors I ran as I was growing up on our farm in central Nebraska. The engine on this tractor, a 1937 John Deere "B", had been stuck for 2 years before he gave it to me. This last spring (1999) I hauled the tractor to our 2 acre lot in St. Libory Nebraska where it joined my antique machinery collection, at that time a 1929 Caterpillar T ... [Read Article]
Latest Ad: John Deere 420 W 1956 with full hydraulic Superior loader.. power steering, direction reverser, touch o magic,3 point, Pto.. Great sheet metal. Runs no smoke. May be a original yellow from factory.Decent tires. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
