550 3 point leaking down
biged706
New User
550 3 point when running with bush hog on back leaks down in about 10 seconds and then picks back up an contines to do this. what should I check besides th cylinder.
Take the 3 point off and set the hydraulic unit in a press and check for leaks There are procedures for this in the Oliver shop manuall. Questions?
(quoted from post at 13:10:51 12/06/23) Take the 3 point off and set the hydraulic unit in a press and check for leaks There are procedures for this in the Oliver shop manuall. Questions?
I didnt know if there could be something with the load and depth control. Thank You
