1958 Cockshutt 550
Marco2
New User
Why do you think it would not move anymore at all. Even when I bring throttle up, nothing happens.
Thanks
Actually , I will try to explain a little more. I purchased the tractor and notice that there was no oil in the transmission, witch made it hard to shift. I put in oil and let it sit for a week. Then all was good , forward and reverse. A couple of days later I decided to fix a leaky power steering then started it up and I can put it in gear , you hear a little difference in motor but does not move at all, either in reverse. When you put it in neutral the engine sounds again a little different.
Thanks again for you reply
Thanks again for the reply
Remove the clutch cover and look and see if your clutch has oil on it. Your front main trans. seal COCKSHUTT 550 SEAL PART NUMBER Z-540 MAY be leaking trans. 80W90 oil onto your clutch.
We have the parts on stock!
Phil Heisey
215-256-8651
A big thank you for the info, makes a lot of sense, will look at that in the spring for sure.
Have a great holiday and thanks for the reply
