Bought an 1800C yesterday. That I knew had transmission issues but I bought it for the loader that s on it to go on my 1850. If I can fix the tractor I m not opposed to keeping it.
I guessing at the gear numbers because I can t read the plaque.
In R1,2, and 4 it will go in gear and drive. In all other gears it grinds. R2 it starts to try to pull its self then grinds. I noticed when playing with the hydropower (non working currently) that sometimes in 4th gear when I shifted back into direct it the tractor kind of fell out of 4th gear. But if you pushed the clutch down and took off again it would go without moving the gear shift. I m not sure if it was just a coincidence that it happened when I was playing with the hydropower or that s what caused it. I could not get it to replicate this often enough to be sure they are a linked problem.
Previous owner states if you pull the hydropower lever up and crack the filter it sprays oil everywhere but it doesn t work.
Thanks for any information!
