nefletcher
New User
Hello all, first time poster, long time observer here. I pulled our old 1650 out of the grass this spring for help with the extra hay we put in this year and after several hundred bales I had a pop then a squeal/whine started instantly. I was coming out of a tight corner turning the wheel fairly quickly to get lined back out and had just gotten the tires straight when it popped. I lost all hydraulics when it happened. I didn't really notice if the PTO had any change as everything got put into neutral as quickly as possible and shut down. I didn't have anything hooked into the hydraulics so I can't test the remotes but there's no steering and no 3pt activity. I'm assuming something sheered or stripped gears in the hydraulics. I had to move the tractor out of the way to hook another machine on and after sitting for several hours there was no change. Goes into gear and runs proper that way although with the engine off I pushed in the clutch by hand and turned the coupler behind the creeper gearbox, it feels rougher like there's a little extra drag. Don't know if that helps but just another possible symptom.
Now that I've described what I'm facing I'll get to the original intent of this post. On Craigslist there's a 1450 in a big "everything goes, make me an offer" type sale and if it runs I thought I'd throw a low ball offer for it if there's parts interchangeability in the hydraulics system. Idler gear, drive gear, hydraulic pump, those sorts of parts. I don't have parts books for either models to cross reference part numbers so I thought I'd come here and see if those who know these Olivers like the back of their hands could help me out on that. I don't know the serial # of the 1450 but my 1650 is 195 536-454. Model number is 365-22093 as well, if that helps. I sure appreciate any input and look forward to learning something new. Thanks.
