1850 broken crankshaft
Hi guys. I have a few questions for you. I have an 1850
diesel with a broken crankshaft. It broke on the front journal
right behind the gear on the crankshaft. The motor ran
great. The only reason I dropped the oil pan was because
the front harmonic balancer was wobbly and would move in
and out more than I was comfortable with. I initially was
going to look at the thrust washers, but obviously I found
the problem. The harmonic balancer looks good and isnt
falling apart or anything. This tractor was overheated and
then overhauled by a really good mechanic several years
before I bought it. It now probably only has 500 hours since
the overhaul. My question is what would cause the
crankshaft to break? I found a crankshaft with matching
numbers and am having it shipped here. Im then taking it to
a machine shop to have it checked. What else do I need to
check while Im at it. Im replacing the main and rod
bearings and seals while Im doing it too. I havent pulled
the engine as Im waiting to make sure the crankshaft is
good thanks for any advice.
We picked up an 1850 from the Farm Science Review back in the Mid 60's> It had a broken Crankshaft the same place where yours broke. Please send me an e-mail J.
(quoted from post at 20:12:04 01/19/23) Hi guys. I have a few questions for you. I have an 1850
great.
[b:65ee56f56e] My question is what would cause the
crankshaft to break? What else do I need to
check while Im at it[/b:65ee56f56e]..
I would suspect crankshaft alignment and would be checking to see if the block needs line-boring.
This post was edited by oliver90owner on 01/21/2023 at 06:45 am.
The cause of your crankshaft failure was a defective harmonic balancer. They can look OK and still not do the job they're meant for. Simple fix is to buy a new one or at least purchase the one that was on your replacement crank, it may be good for years or weeks?
Does anyone know where I can get a new harmonic dampener ? Maibachs dont have one but it can be sent in to rebuild it. That would probably take at least a month to ship it back and forth. Thanks again for your advice.
