Company Logo (800) 853-2651 Shop Now
Order Ford 9N Parts Online
RPM's on a 9N
Ron Tron
01-23-2023 14:28:04
as I have said many times before I have two 9N's. Both are converted to 12 volt system with Pertronix ignition units. Only one has been totally converted to a can style coil and that I presume you just measure the RPM's with that coil wire. But how do you measure RPM's on a square can coil?
Leroy
01-25-2023 17:46:51
 Re: RPM's on a 9N in reply to Ron Tron, 01-23-2023 14:28:04
I don't ever remember having a need to check the RPM's on the 44 2N Ford that is still 6 volt and will stat that way. Dad may have checked PTO RPM's for the PTO combine but that was before my time and 79 now. Just never had a need for that.
Mad Farmer
01-24-2023 14:32:30
Old fashioned tach/dwell meter
Third Party Image
Ron Tron
01-24-2023 14:14:14
[quote="CVPost-deanostoybox"](quoted from post at 13:34:13 01/24/23) Ron Tron
For the square coil, since you already have a hole in the distributor for the red wire that supplies power to the Pertronix unit from switched side of ignition switch, you can add another wire from the concave screw where the black wire from the Pertronix unit goes to through that same hole. You can then use that wire to connect your tach.[/quote
thank you..... .....makes sense..... ...so basically you connect your tack to the pertronix black wire at the concave screw that connect to the bottom of the square can coil. the same wire you connect to the negative side of a can coil right?
deanostoybox
01-24-2023 14:20:19
 Re: RPM's on a 9N in reply to Ron Tron, 01-24-2023 14:14:14
Correct.
deanostoybox
01-24-2023 12:34:13
Ron Tron
John Deere D
01-24-2023 08:54:30
TRY:
On the internet enter:
electrical tachometer connection for a four cylinder gasoline engine
Read information..There is a Telephone Number to call for assistance...
Ron Tron
01-24-2023 08:07:00
Are you aware of how to hook up a tachometer on a conventional engine?
Tim PloughNman Daley
01-24-2023 06:01:23
Engine RPM'S has nothing to do with the coil. Hand held tachs are available as JMOR noted.
Third Party Image
Tim Daley(MI)
