Folks,
With much gratitude to this forum, I was able to get a very stubborn rear wheel off a '47 2N and pull the axle.
To my surprise it already has an axle sure seal installed. Since the brakes are saturated, and there are numerous punch marks on the seal's flat surface, it needs to be replaced.
Any pointers on removing the existing sure seal?
Also, there is a thin gasket between the brake backing plate and the axle housing. I don't see that in the FO-4 shop manual. It is in YT's parts listing as PN 9N4130, item No 153608.
I believe I want to replace that seal. Yes?
Thanks,
Bill
Thanks,
Bill
