massey 50 hydraulics
andydap
took off the transmission cover to get to the hydraulics. change the oil, new filter, new piston and rings, new o-ring under the cylinder. forgot just how the linkage goes back together with the two fingers, but i think i can eventually figure it out. what i can't figure out is how to adjust the position and draft fingers. i watched that you tube of rachel gingell twenty times and still can't get it right. anyone know where or who i can ask how to do this?
thanks,
befuddled
When placing the lift cover back down the two fingers must be in FRONT of the pump lever roller, I use the dipstick through the lower hole to hold the pump lever back when replacing the lift cover.
