Eazycheeze
Hey guys , so winters here and my pump does not like the cold . When its warm it works awesome but when its below -15 I have to wait and run the pto for 30 minutes before I can use the 3pth or my plow.
Ive come across videos of people replacing their relief valve with a MODIFIED relief valve too accommodate nee oils, would this help me in any way with cold fluid or should I try a block heater on the externals of the tractor sump too get heat in it. When the fluid gets heated all my hydraulics work fantastic and it holds my implements in the air for week or two before it drops down so it retains pressure.
Thank you!
Thank you!
