My 1969 135 MF 3 cylinder gas has a distributor that has over 1/8 inch of end play and the advance weight assembly has started rubbing around the inside bottom of the housing. No wander it would only idle.
Has anyone had this happen to them, or maybe knows a good carburetor and Ignition man that can sell me the bushings for the housing. I will purchase a used unit too.
Delco Remy # 1112 457 9H3
MF # 521189M91 I think this is the correct MF number.
This is a 3 cylinder Perkins gasoline engine so it doesn't have to be from a 135 tractor, it just needs to be 3 cylinder perkins gas.
Thanks for your time;
Boowah, South Ga.
Boowah, South Ga.
