Don Ober
I have a 135 PTO spins like it is in gear but the leaver will not work feels like it is not working ( like the yoke is not moving the selector) PTO will still turn by hand with the power off and trans.in gear. I haven t pulled the side plate yet; any guesses as to what is wrong?? THANKS
Im guessing it has the IPTO hydraulic clutch pack. What you describe is what happens when the clutch discs and spacer plates are burned and warped. This damage usually happens when hydraulic oil is low, or control lever not moved to fully on position.
