Hay maker2
Please educate me on the John Deere hydraulic pumps.
I m referencing the pumps below
AR94660 50 CM3
AR94661 65 CM3
I know that that the 60 CM3 is a larger pump.
How much fluid does the 65 pump compared to the 50?
What does CM3 stand for?
In know that the 63 CM3 pump has a larger inlet and outlet, but when I do a where used it shows the same O-Ring part number for the fittings on either pumps. This tells me that the fitting is the same size
Is there any negative effect by installing larger pump?
Thanks
AR94660 50 CM3
AR94661 65 CM3
Thanks
