Company Logo (800) 853-2651 Shop Now
Break in for a JD 4440
Le9102011
01-24-2023 19:06:15
Hello all, I have a JD4440 that just got a long block engine replacement from Abilene Machine, and i was looking for some pointers on how to break in the new engine, The guys at Deere told me that I will need to hook up a disc or renovator and run the snot out of it for a few hours, which is contradictory to what i tell people when they purchase a New Diesel truck. I know a lot of people on here have farmed with Iron Horse Tractors, and it will only really be used to farm our tractor club field of 8 acres go to various shows and pull a hay wagon.
Tractor only has 3500 Original hours, and was told it lived a non abused life to cultivate cotton in Peoria Arizona. Tractor was parked due to a liner seal leaking and engine was ran hot a few times, with ditch water as coolant so that is the need for the long block. Block was toast due to corrosion head had a crack but crankshaft was fine.
shanker
01-27-2023 19:30:41
 Re: Break in for a JD 4440 in reply to Le9102011, 01-24-2023 19:06:15
Zinc dialkyldithiophosphate (ZDDP) in gear head terms is an additive that was formerly used in engine oil's to help minimize wear especially at the interface of a hydraulic flat tappet lifter, and camshaft.
It was significantly lowered by EPA due to lowering emmissions.
If you want to go down the rabbit hole, here are the two best online resources:
Link
https://540ratblog.wordpress.com/
620 John
01-26-2023 17:13:51
Last fall I installed a reman engine in a JD 7830 which is a 6.8 engine. What WTW posted is pretty much what JD's instructions are that come with reman engines. I'll have to see if I can find those instructions again.
WTW
01-25-2023 16:41:08
Use it, Don't abuse it.
Don't baby it and Don't beat it.
The more variation in load the better.
If you had a short field to plow and had to turn around in short passes would be perfect. The most important thing is to make sure engine is up to normal operating temperature before you work it. If it was mine I would run the first 100 hrs with break-in oil. Do not let it set and idle.
Tx Jim
01-25-2023 04:27:58
I had pistons/liners installed in my 4255 year before last. It had ""JD break in oil"" in it when I picked it up at JD dealership. I drove it home & attached it to my JD 467 rd baler. I started using it to bale hay. Rings must have seated because it uses no oil between oil changes
tim s
01-25-2023 04:15:49
Make sure that you use a Zinc additive in the oil,, and run it like you did before..I rebuild 15 or so each year,,sent them home to work and they break in fine...
dwag
01-27-2023 19:08:10
 Re: Break in for a JD 4440 in reply to tim s, 01-25-2023 04:15:49
Whats zinc additive? Where do you get it? Doesn't Deere break in oil contain it?
craigco
01-25-2023 03:06:14
Last 2 engines replaced at work came with break in instructions. One was a 6 cylinder cat motor the other a 4 cylinder Cummins in a skid. Both said run at 3/4 load for 8 hours with minimal idle time.
matthies
01-24-2023 20:05:55
Whenever I overhaul one in my little shop it goes to the dealer or an independent shop I know well, and gets ran on a dyno for 8 hours or close to it.
Today's Featured Article - A 1937 John Deere Unstuck - by Gary Hickman. Here is my story of how I got the pistons out of a 1937 JD B that the engine had been stuck for about 14 years: About 12 years ago my Dad gave me one of the tractors I ran as I was growing up on our farm in central Nebraska. The engine on this tractor, a 1937 John Deere "B", had been stuck for 2 years before he gave it to me. This last spring (1999) I hauled the tractor to our 2 acre lot in St. Libory Nebraska where it joined my antique machinery collection, at that time a 1929 Caterpillar T ... [Read Article]
Latest Ad: John Deere 420 W 1956 with full hydraulic Superior loader.. power steering, direction reverser, touch o magic,3 point, Pto.. Great sheet metal. Runs no smoke. May be a original yellow from factory.Decent tires. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
