cookieman8772
I still cannot make this tractor run. Carb has been sent out and rebuild professionally. Magneto and ignition system is professionally rebuilt. New head gasket. It may start, but it doesn't run right. Won't increase rpm.
I don't understand why it has 130 psi compression. There's no mechanical reason for that other than not stock pistons. (Tractor is all fuel).
The magneto seems to be firing even on the exhaust stroke. Tried advancing timing. No luck. It has a strong blue spark thru the plugs.
Carb was ran on another tractor and worked as designed.
The flywheel is rotating counterclockwise on an electric starter.
Intake and exhaust systems are clear and pose no restrictions.
I have no idea why it won't run.
