1946 BN IHC
we have an Ingersoll Rand [case 224] with a Kholer 14 hp., engine.
Here is the difficulty>> >>keep in mind even added jumper cables from the car battery with the car running << When attempting to start the Kholer 14 hp., the starter generator would only turn the flywheel till compression was reached. ( drive Belt snug)[ even put the jumper cables directly on the starter large lug, the same thing happened].
Took plug out engine turns over freely, tested for compression [thumb method] >>starter motor stalled again on compression stroke<<.
Up to this point in time the >>last time started the engine 2 weeks ago started easily ran well<<.
Yesterday as I went to started the engine, it would start on choke, and run for about for about a minute and stop. then restart after several turns and run for a minute then stop. Repeatedly. Today the above difficulty took place.
I am stumped run, out of ideas and thoughts as to where to look and what to do.
Thank you for any thoughts and ideas as to where and what to do.
Wm. from Ontario Canada.
