need deck runner for Husqvarna LT 1238 lawn tractor
It SUCKS when parts for a relatively new piece of equipment are discontinued!
Is yours badly worn, bent or missing altogether?
It is a simple part, should be easy to repair or make.
If you don't have the tools and/or skills to do that there must be a welding shop within a reasonable distance form you that could help you out.
It wore through in the middle and broke;I'll have to try to cobble something up I guess.Thanks for the suggestion though! :)
Typical repair for a runner of any sort is to weld up or have welded up, a replacement runner with a bigger ground contact plate.
