davyfireball
I replaced the head gasket on the unit. I set the piston on TDC and tightened the hydraulic valve to 100 inch pounds. Sealed it up - It was Dieseling real bad - wouldn t idle . So I took it apart and set the piston about 3/16 After TDC and now it runs better. My question is how do I set timing on this critter.
And don t worry about carbon on head or valves ( it s clean)
This post was edited by davyfireball on 09/18/2023 at 11:30 am.
